Forum: Old versions
Topic: Treble & Bass
How am I possible the Treble & Bass bud to fix, if I number another one
beginning jumps he to the middle ?
geposted Tue 15 Aug 06 @ 8:12 pm
erxonPRO InfinityMember since 2003
Huh? First of all, try writting a sentence, this is impossible to decode.
The only clue I found that would make sense after reading it 10 times, is that you don't want the EQ to reset after loading a new song. If that's it, disable the Auto EQ-reset under Fame Settings in VDj properties.
geposted Tue 15 Aug 06 @ 8:49 pm
Yess ok thanks its working now ;)
geposted Tue 15 Aug 06 @ 8:58 pm
