Hi, I was thinking of purchasing the ConsoleDJ thing lol ;]
But anyway, If i was to purchase that [ From Argos! lol ] Is it the Newest Edition Of VirtualDJ which has the 'Put your hands up in the air' FX's already installed.
And if it isn't and i would like to purchase VirtualDJ[Newest Edition], how would i use the actual Console From Hercules ConsoleDJ with VirtualDJ if i Purchased the actual VirtualDJ Edition?! ;]
Thanks
Sean
Thanks
Sean
geposted Fri 18 Aug 06 @ 1:18 am
go here to see what you get with the different versions
the upgrade is definately worth it, you get console mapper, effects, skins, samples, DJ on the radio, all sorts of things
geposted Fri 18 Aug 06 @ 1:28 am
Thanks Xeo,
Do you know if i will get the 'Put your hands up in the air' tune ? lol ;]
geposted Fri 18 Aug 06 @ 1:41 am
you do with the version i have, the full one, i think you would probably get it with the console version too
geposted Fri 18 Aug 06 @ 2:16 am
Ok,
Thanks for the help mate..
Sean
Sean
geposted Fri 18 Aug 06 @ 2:19 am
Seaneh wrote :
Thanks Xeo,
The track that you are looking for is UBP feat Bobby Pruit - We Are One, and it's the Hands-Up-A-Pella that you want, which can be found here...
http://www.traxsource.com/index.php?act=show&step_id=82d2b5ff0e94c53e68490349fd59f78f&fc=tpage&cn=title_id&cv=566
geposted Fri 18 Aug 06 @ 4:10 am
