Forum: Old versions
Topic: quick question on transferring mp3's
sinoksPRO InfinityMember since 2006
hi guys,
gotta a ? here: installed a new hd, transferred all mp3's to my new hd, where do i find the vdj database which stores all the info on the songs - for now i cannot find it. please tell me its there somewhere....
sino
geposted Fri 18 Aug 06 @ 9:24 pm
The VirtualDJ Database.xml stores all song information about bpm, cues, gain etc...
This is the database to keep!
The mp3database.txt ONLY contains PATH to the mp3 files, and if you have moved your MP3 files, simply add the new folders to favorites inside VDJ, and right-click and choose "add to search-database" on the folder.
That will rebuild the mp3database.txt, and make VDJ see the new paths...
Hope that helps ;)
geposted Fri 18 Aug 06 @ 10:03 pm
And these files are stored in the folder where you installed VDJ, which is default C:|Program Files|VirtualDJ
Ewout
geposted Fri 18 Aug 06 @ 10:07 pm
yes ;)
geposted Fri 18 Aug 06 @ 10:10 pm
thnx a million guys! saves a lot of searching !! :-)
geposted Fri 18 Aug 06 @ 11:18 pm
