Forum: Old versions
Topic: Newbie needs some help with set up...
matguyHome userMember since 2006
Hi all
Have just downloaded the demo after watching a friend use the full version at a house party. Looks good and am looking forward to getting stuck in.
Have a question though...
I have a laptop with one sound card, my stereo to connect up to play the sound.
How do I get the programme to cue up tracks on the ear phones and carry on playing the main body of music through the hi-fi?
I'm guessing I probably need the full version don't i? Like most things! I can see from the on-line mannual that i should be able to do it.
Any help very muchly appreciated!
Regards,
Mat
geposted Mon 21 Aug 06 @ 1:35 am
xeonPRO InfinityModeratorMember since 2004
yup, FULL PRO version needed ;)
geposted Mon 21 Aug 06 @ 10:33 am
To get the laptop and stereo working right, will i need to set it as such:
Sound card in laptop to phono splitter (I only have one phone out on laptop!!) - 1 to connect to stereo for the speakers and amp and 1 to headphones to cue.
Once full pro version held then I should be up and running right?
Mat
geposted Mon 21 Aug 06 @ 12:34 pm
correct. but i can advise you buying external sound card with at least 2 stereo outputs. Look for u46DJ too ;)
geposted Mon 21 Aug 06 @ 1:06 pm
I thought I might have to upgrade the sounds at some point. They the weakest thing on my laptop!
Can you recommend some good but fairly reasonable priced carrds to look at?
I see there are ones to fit a PCMCIA but not sure if they are any good.
Am really looking forward to getting this going now!!
Mat
geposted Mon 21 Aug 06 @ 7:34 pm
pcmcia are good, but you can choose U46DJ too. it is actually the best card to use with VDJ and TC
geposted Mon 21 Aug 06 @ 11:29 pm
