Topic: V3.x and v4.x at the same time ?
Can I have v 3.x and v4.x installed on my system at the same time to do some testing with v4.x before I play out with it in front of people ???
I want to be able to use v3.4 until I have time to test v4.x and make sure it's stable :)
geposted Mon 21 Aug 06 @ 8:03 pm
Should work. Just install it under VirtualDJ4 folder or something similar :)
just rename the virtualdj.exe to virtualdj_34.exe, before the install of VDJ4.
And you can run both version ;)
either of the 2 ways mentioned above will work, just make sure u back your database up
Wouldn't you need a full install to have both? Usually there is just an upgrade.
More than likely it will be a full install if it isn't do as Norway said earlier rename the old vdj. exe to something else
It will be a full installation file I'm pretty sure.
