Forum: VirtualDJ Skins
Topic: SEPARATE WAVES !!!
Man-TkPRO InfinityMember since 2004
Can somebody do some changes for SEPARATE WAVES ????
I'm using default skin (vdj4) without waves but I need them ...I need them but separately !!!
Divide by 2 actually waves ...left side only for deck 1 and right side for deck 2 - (like traktor )
I need to do some changes here (I don't know how) :
<rhythm>
<size width="958" height="51"/>
<pos x="33" y="25"/>
<chan1_active1 x="+0" y="+1197" />
<both_active1 x="+0" y="+1281"/>
<chan2_active1 x="+0" y="+1365" />
<chan2_active2 x="+0" y="+1965" />
<both_active2 x="+0" y="+2049"/>
<chan1_active2 x="+0" y="+2133" />
<grid1 width="5" mainwidth="11">
<size width="958" height="9"/>
<pos x="33" y="77"/>
<active1 x="+0" y="+1197"/>
<active2 x="+0" y="+2133"/>
</grid1>
<grid2 width="5" mainwidth="11">
<pos x="33" y="87"/>
<active1 x="+0" y="+1365"/>
<active2 x="+0" y="+1965"/>
</grid2>
<cue1>
<down x="+0" y="+1197"/>
<mask x="712" y="2879" width="9" height="10"/>
<text dx="9" dy="0" font="Virtual DJ" size="10" color="#B0E0FF"/>
</cue1>
<cue2>
<down x="+0" y="+1965"/>
<text dx="9" dy="0" font="Virtual DJ" size="10" color="#FF6868"/>
</cue2>
</rhythm>
THANKS
geposted Tue 22 Aug 06 @ 6:29 pm
DJ FORMATPRO InfinityModeratorMember since 2003
We are close to releasing our Denon skin for V4.0 which has separate rhythms in it, once it hits the site you will be able to review the XML used. It is a bit harder as you need to have 2 rhythm scripts.
geposted Mon 28 Aug 06 @ 2:17 am
