Forum: Old versions
Topic: backspinning & jugglin with tcv on version 4
Still not what it's supposed to be, when I backspin, timecode signal get's lost. (Same in v3.4)
Soundengine is idd much better
Greetz Dasouth
geposted Thu 24 Aug 06 @ 1:19 pm
apopsisdjPRO InfinitySenior staffMember since 2003
...but corrected immediately when record play forward again (not in 3.4)
Be sure to have absolute mode and antiskip off.
geposted Thu 24 Aug 06 @ 1:25 pm
I'll try it tonight, gotto work now
Damn fast reply ;)
geposted Thu 24 Aug 06 @ 1:33 pm
glad to help..
Keep in mind timecode is not readed correcly in reverse, (this is the case with most vinyl software). So in 4.0 if needle jumps in reverse (backspin or scratch) possition is corrected when it reads normal (forward) timestamps again.
geposted Thu 24 Aug 06 @ 2:16 pm
listen2PRO InfinityMember since 2005
If your needle is losing track it is probably skipping/jumping out the the grooves.
Smart mode with anti skip work the best!
geposted Thu 24 Aug 06 @ 4:09 pm
You're right it works now,
I really start to like the new bpm engine
nice work dev team
geposted Fri 25 Aug 06 @ 10:29 am
good to hear..
geposted Fri 25 Aug 06 @ 11:48 am
Dj XeoPRO InfinityMember since 2005
there is a new BPM engine?
geposted Mon 04 Sep 06 @ 2:13 am
adro90Home userMember since 2006
my beat juggling is messed up....whenever i click the button it has a delay or sumthing and doesnt chop it right.....can someone plz tell me what i can do to fix this problem....
geposted Fri 22 Sep 06 @ 4:25 am
