Forum: Old versions
Topic: Audio bleeding with v4 and MK2?
woodsyPRO InfinityMember since 2004
Good work on the new version 4, I like the new lay out, however...
are you aware of the channel bleeding (or some kind of cross contamination of the audio) with V4? it happens when moving the jog wheel or crossfader on the MK2, it sounds as if a fader has dirt in it.
So if you play something on deck 1 and turn the jog wheel with the next tune on deck 2 to que you get bleeding, even with the cross-fade fully over and the volume down on the second deck.
I've tried all the different settings in config "performace", the best setting is "fastest" , but even with this setting there is still a strange gritty sound in the background if moving the wheel on the silent deck.
Also the "limiter" function and "time strech disable" is missing in V4
I advise ppl to set a restore point before installing V4.
I'll go back to V3.4 till it's sorted.
geposted Thu 24 Aug 06 @ 3:34 pm
