Hi, I just installed the update for vdj and I have a hercules dj console mk1 so I tried it, everything work very good. But I want to use my monitor it didn't worked. I don't know what I do rong but when I go to my Dj Console mixer and take the main channel to use for monitor it works. But not when I trie tot pfl a song it dont work, can someone help me
(sorry for my bad english)
geposted Thu 24 Aug 06 @ 3:48 pm
yeah i have the same problem, :( I hope they havn't left us MK1 users behind... lol
Annoying though isn't it! :o(
geposted Thu 24 Aug 06 @ 11:10 pm
should work ... Will test my old console
geposted Fri 25 Aug 06 @ 3:51 am
it's ok
You have to use the drivers from the hercules website 2004
link: http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=143&cid=1
, In audio config try:
Output: Headphone
Sound card: DJ console
that works with me
Solarius
Output: Headphone
that works with me
Solarius
geposted Fri 25 Aug 06 @ 4:04 pm
Same settings for me and works great
geposted Fri 25 Aug 06 @ 5:55 pm
I've got the old dj console aswel, but when monitoring tracks over the headphones I cant seem to get the EQ's to adjust. That is i can adjust the knobs but nothing happens when listening through the headphones.
I dont know why this is happening in VDJ 4 as it worked fine in all previous versions.
Could it be the Hercules Driver? or is it VDJ 4?
I've adjusted the sound options to OUTPUT - headphones and SOUNDCARD - Hercules
Would really appreciate it if some one helped me out. Thanks alot!
geposted Sun 27 Aug 06 @ 4:27 pm
use the 2004 driver, link : http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=143&cid=1
This driver works fine. Don't use the drivers for the Mk2 there not so good for the mk1
solarius
solarius
geposted Sun 27 Aug 06 @ 9:00 pm
I tried all the drivers 2004, 2005 and 2006 nothing seems to be working!
I just dont know what to do!
geposted Sat 02 Sep 06 @ 5:58 am
