Hello,
I can't change pitch speed with beatlock on in version 2.00
Is there a option ?
Best regards
Is there a option ?
Best regards
geposted Tue 29 Jun 04 @ 1:47 pm
it sounds like you are not using a version 2.00 compatable skin.
check the addons page for an update as the beatlock is now per sedk instead of just one button. when pressing the beatlock button on an old skin both decks beatlocks are enabled and as a result doesn't work correctly
geposted Tue 29 Jun 04 @ 2:21 pm
djzero
When a track is beatlock you can't change the pitch because this the track who need to be syncro with the other.
geposted Tue 29 Jun 04 @ 2:51 pm
yes you can, with beatlock enabled you can move the slider on the non beatlocked deck and the slider on the beatlocked deck will move in unison keeping the two in time. if both beatlocks are enabled then the pitch controlls are locked in position and cannot be moved at all
geposted Tue 29 Jun 04 @ 2:57 pm
you're right but if kaboem ask for a pitch changing of the beatlock song he can't.
geposted Tue 29 Jun 04 @ 2:59 pm
sorry Dj Morris your right, diddn't quite read his question properly
geposted Tue 29 Jun 04 @ 3:01 pm
Djzero,
In version 1.09 you can change the pitch speed with beatlock on, i,am using the orginal skin of VDJ.
Thanks
Thanks
geposted Thu 01 Jul 04 @ 2:53 pm
