Topic: Don't believe the hype...4.0
Dj-LosPRO InfinityMember since 2005
Hi All,
First I say thanks for your efforts on trying to improve what was a very stable and comfortable s/w to use.
But I must say that 4.0 is flawed to the point of not usable at a live venue/gig.
just some of the issues so far.
1. Did not install over existing 3.4, locked up on fonts twice, removed 3.4 and directories, then installed just fine.
2. locked up when after loading second song.
3. task manager killed it, restarted vdj4, and locked it up again.
This is something I did not have the pleasure of experiencing with past versions.
Also, a minor side note, I see that if you load a song and wait it marks it as played after 40 seconds though it was not played just loaded, this was supposed to be fixed in 4.0.
Sorry guys, I'll be waiting for the sequel.
-DjLos.
geposted Thu 24 Aug 06 @ 8:48 pm
phillydjPRO InfinityModeratorMember since 2004
did u adjust all the performance setting to fit you pc?
geposted Thu 24 Aug 06 @ 8:49 pm
is there a particular setting you feel might help?
new problem - Can't even get the visulizations to work, any of them.
only spent a few minutes on this version 4, it is not holding up.
-DjLos.
geposted Thu 24 Aug 06 @ 9:08 pm
geposted Thu 24 Aug 06 @ 9:13 pm
try disabling the overclock feature in the performance tab, also setting it on low (still sounds better than 3.4) and working up from there
geposted Thu 24 Aug 06 @ 9:24 pm
