Forum: Old versions
Topic: So in theory?
stuxxxPRO InfinityMember since 2003
If i install virtual on both my laptops via their internal soundcards and seperate extigy's to my mixing desk,
if i then take a line out from both the laptops plugged into the other laptops line in.
I should be able to beatlock between all four decks..
i think thats right? Help its friday my head hurts!!!
Stu
geposted Fri 04 Jul 03 @ 6:50 pm
HomeboyPRO InfinitySupport ManagerMember since 2003
Ya pretty much but you will not be able to move all the curves via the mouse on the same pc.
geposted Fri 04 Jul 03 @ 7:46 pm
Why not, might require some trying to see what configuration of the sound setup in vdj is best.. depends how you plan to do the cueing.. if you going to mainly use external mixer, it might work by having the record out from external mixer to go into the other laptops line-in...
if your going to do mixing totally in the vdj's, there might be some trouble setting the cueing properly....
geposted Fri 04 Jul 03 @ 7:47 pm
Thinks its gonna be my project for Sunday when I get up! working till 6am Sun morn........
will advise.........
Stu
geposted Fri 04 Jul 03 @ 8:50 pm
