Topic: Adding Effects in 4.0
chansinPRO InfinityMember since 2006
How do you add effects if you just have 4.0 installed and you did not have 3.4. I had to do a system restore and then just installed 4.0. When I try to install an effect I get the error "no software found". I know how to do the effects from 3.4 but problems with just 4.0
Chris
geposted Tue 29 Aug 06 @ 4:02 am
It will be fixed. The old plugins are compiled for 3.4, and looks for 3.4 install
geposted Tue 29 Aug 06 @ 8:26 am
djcelPRO InfinityModeratorMember since 2004
Some plugins are already updated (when it's written "it only works for VirtualDj v4.x and Numark Cue"), the other ones wil come little by little
geposted Tue 29 Aug 06 @ 1:18 pm
