In BETA at the moment *** New DMC/DAC2 Mapper for VDJ 4.0, DMC Optimized ***
Note: This Mapper only works 100% with VDJ 4.0
This mapper is Using jpboggis excellent mapper code as a base and also parts of halo_djk's latest mapper functionality. Thanks to both of them.
I made this mapper since i really wanted to have this functionality on my DMC, and every DMC/DAC2 mapper here uses the [ FX ] button that the DMC doesn't have. With this mapper i now have almost total controll over all important functions without using extra controllers/kbd etc. But you can also use it with DAC2.
- DMC Optimized ? -
Simply, functions using the [ FX ] button on DAC2 are also mapped to other buttons to use on the DMC1. Also, some button-combinations that works on DAC2 doesn't work on the DMC.
Below is the functionality i have working in the current beta version. If you think i should add, change or remove anything just let me know. I will release it very soon, but if you want a beta version, just send me a message.
-- Generic Buttons --
There are 2 buttons that doesn't have any functionality by there own and are only used in combinations with other keys, these are:
* [ WAITLIST ]
* [ SHIFT ]
-- Core Function keys --
* [ Play/Pause ]
Pressing this button generates a PLAY/PAUSE. Using [ SHIFT ] + [ Play/Pause ] generates a STUTTER PLAY. Using [ WAITLIST ] + [ Play/Pause ] plays the selected loop Sampler.
* [ CUE ]
Pressing the [ CUE ] button makes a track stop. [ SHIFT ] + [ CUE ] sets CUE Pos #1.
[ WAITLIST ] + [ CUE ] autocues to the first beat of the song.
Pitch Bends the track forward while being pressed.
Pitch Bends the track back while being pressed.
* [ MATCH ]
Applies a Beatlock, Beatlock is released when you release the key. To Lock Beatlock press
[ Shift ] + [ Match ], to unlock, just repeat. [ WAITLIST ] + [ MATCH ] generates a PITCH RESET.
* [ LOAD ]
Loads the selected Track into the player. [ SHIFT ] + [ LOAD ] (DAC2 only) toggles between Elapsed and Remain time in the players, note that time is calulated out for real time display taking pitch into account. The Progress Bar will also flash when the track has 30 seconds remaining, and faster when 10 seconds remain.
-- Jogwheel --
* [ Inner wheel ]
This performs a track nudge to set cue points while not playing, and a mild pitch bend while playing.
Hold [ Shift ] and then use the wheel to browse the record library.
* [ Outer wheel ]
This is used to Seek throughout the track, if used with [ Shift ] it will change directories in the browser.
-- Loop handling --
The Loop function of the mappper uses 3 buttons.
Decrease Loop time, loop length is shown on the left of the display.
Increase Loop time, loop length is shown on the left of the display.
* [ GROUP ]
Apply Preset Loop as shown in the display, a second press will exit the loop. When player is in loop play mode, "SINGLE" is shown in the display.
-- Effect handling --
* [ PREVIEW ]
This button activates/deactivates the selected effect.
* [ SHIFT ] + [ + ]
Selects the next effect in the effect list and makes it the active one.
* [ SHIFT ] + [ - ]
Selects the previous effect in the effect list and makes it the active one.
// Note: DAC2 function only //
If you are using DAC2 you can also use the [ FX ] button.
* [ FX ]
* [ SHIFT ] + [ FX ]
* [ WAITLIST ] + [ FX ]
-- Loop Sampler handling --
* [ WAITLIST ] + [ Play/Pause ]
Playes the selected Loop Sample.
* [ WAITLIST ] + [ + ]
Selects the next loop sample in the list and makes it the active one.
* [ WAITLIST ] + [ - ]
Selects the previous loop sample in the list and makes it the active one.
- DMC Optimized ? -
* [ WAITLIST ]
* [ SHIFT ]
* [ Play/Pause ]
* [ CUE ]
* [ MATCH ]
* [ LOAD ]
-- Jogwheel --
* [ Inner wheel ]
* [ Outer wheel ]
-- Loop handling --
* [ GROUP ]
* [ PREVIEW ]
* [ SHIFT ] + [ + ]
* [ SHIFT ] + [ - ]
* [ FX ]
geposted Wed 30 Aug 06 @ 3:20 pm
Now uploaded to VDJ website for release, change requests will be in the next version.
geposted Thu 31 Aug 06 @ 10:48 am
How long does it normally take for the site staff to release a tool ? It's now 5 days since i uploaded this.
geposted Mon 04 Sep 06 @ 7:56 am
We have to verify the files first that's why sometimes it can be long
geposted Mon 04 Sep 06 @ 12:16 pm
np, i understand that. Just interesting to know since i was not sure if the upload was ok or not.
geposted Mon 04 Sep 06 @ 12:50 pm
i think it takes a little long to put plugins on the site but anyway good work guys
geposted Mon 04 Sep 06 @ 3:59 pm
Any updates available that are compatible with 4.1?
geposted Sun 15 Oct 06 @ 10:22 pm
I will be finished with the 4.1 version BETA this week. And final release version also i hope.
geposted Mon 16 Oct 06 @ 7:09 am
I'd be glad to test it :-)
Nice day 2 all... and happy coding
geposted Mon 16 Oct 06 @ 1:34 pm
We are waiting for version
geposted Wed 18 Oct 06 @ 7:06 am
Sorry Azian, You need to enter your serial before plugin downloads will work for you.
geposted Wed 18 Oct 06 @ 10:51 am
