Topic: VDJ 4.0 playlists.
On installing VDJ 4.0, it asked whether i would like to import itunes playlists. Well it did but is there a way to keep this virtualfolder synchronized with the itunes playlist? This way if I edit the playlist using itunes, it automatically makes the same changes in the VDJ virtual folder.
geposted Wed 30 Aug 06 @ 11:01 pm
Yeah, ok I guess no ones ever thought about this
geposted Thu 31 Aug 06 @ 5:11 pm
Not sure how iTunes playlist are formated and stored....
But if you know, you can try to make the iTunes playlist folder favorite folder inside VDJ.
That would make it dynamically, IF iTunes have standard playlist format (might not)
geposted Thu 31 Aug 06 @ 5:16 pm
They don't I can't find them anywhere. Also when I was adding music to a virtual folder, VDJ would hang on me. It's happened several times.
geposted Thu 31 Aug 06 @ 6:26 pm
I've actually found out how it happens. It happens if you drag more than one song to the virtual folder.
geposted Thu 31 Aug 06 @ 6:57 pm
