Topic: Using CD Player's Cue and Loop Functions
chabonkPRO InfinityMember since 2004
Hi guys, I've upgraded to v4.0 and I'm trying to configure my system correctly. I'm using a pair of CDXs with timecode CD's to control VDJ in absolute mode. I think I may be overlooking something here. When I cue or loop with the CDXs, the cues and loops are a bit delayed. Thanks!
geposted Thu 31 Aug 06 @ 12:06 am
what soundcard, and what latency ?
geposted Thu 31 Aug 06 @ 12:10 am
I'm using Maya44 and latency is set to Auto with Safe Mode and Overclock checked. Everything else is running flawlessly. Looping and hot cues with the CDX controls are slightly delayed. I'll keep playing with the settings, but if someone's already climbed this mountain... please post up. Thanks!
geposted Thu 31 Aug 06 @ 1:53 am
Just in case anyone else is experiencing this, I was able to fix my problem by NOT using "Auto" as my sound card latency option. Happy mixing!
geposted Sat 02 Sep 06 @ 3:28 am
apopsisdjPRO InfinitySenior staffMember since 2003
The "auto" just use the buffer/latency settings from the card directly, like it was in 3.4
Propably it's set to a high buffer/latency in maya's panel.
I use "auto" and "fast" or "rapid" in maya.
What latency works for you now ?
geposted Sat 02 Sep 06 @ 4:04 am
