Topic: please HELP!
djturkPRO InfinityMember since 2006
I have installed the new updated program...I have the dac3 working but my mixer (MP4) is not working... both decks coming out of one side of the mixer......
geposted Fri 01 Sep 06 @ 6:24 am
DJ-ALFPRO InfinityModeratorMember since 2005
What sound card do you have? Have you selected in Sound Setup 4 channel output?
geposted Fri 01 Sep 06 @ 6:42 am
MY sound card is in the Rane MP4....so I am not sure what to choose from drop down menus....I have a reception to do this evening....I still can not get it to work.
geposted Fri 01 Sep 06 @ 3:11 pm
I don't know that card, but I will presume it is at least 4 channel.
If you using mixer:
Outputs:External Mixer
Sound Card(s):4.1
Front output is left deck, Rear output is right deck.
If you don't use mixer than:
Outputs:Headphones
Sound Card(s):4.1
Front output is Master out, Rear out is your headphones.
geposted Fri 01 Sep 06 @ 4:35 pm
i think you might need the "external mixer" setting. you select that, then chose your card from the dropdown list below. Then there should be another box below that to let you choose which output goes to which side of the mixer.
geposted Fri 01 Sep 06 @ 4:58 pm
I have tried different setting still both decks plays from one side of the mixer.....
I have 2 hours left for my gig....I am stuck now!
I will try to reinstall the older version.
geposted Fri 01 Sep 06 @ 7:51 pm
ruby23Home userMember since 2006
skin CDJ1000 Version 4 plis download --@--.--
Moderated by Lady Cameron
Sorry ruby23 no email address is allowed from a demo user
geposted Fri 01 Sep 06 @ 8:31 pm
Is it possible to use a 3 or 4 channel output (for an external mixer) with the new virtual dj 4.0? as far as I know, it was possible with versions 3.4 and older. I think there was an option called 7.1 in the sound configuration, but not sure because I don't have access to it ;)
I'm asking this because I've read the VDJ 4.0 starters guide which dj-in-norway wrote, and the menus lack an option for 7.1 (or at least 5.1) output. So is it possible (as of today) to use a multi skin, an external mixer, and 3 simultaneous channels to mix in VDJ 4.0?
That was basically what I was wondering.
Thank you in advance:)
geposted Sat 02 Sep 06 @ 5:41 am
Yes, you can use 3 channel mixer: 2 channels for decks and 1 for samples.
geposted Sat 02 Sep 06 @ 6:06 am
I did not have time to experiment all of the settings...I installed the older version for now (because I had a gig to do)
I will reinstall 4.0 and try. everyones suggestions. Thank you very much for now :(
geposted Mon 04 Sep 06 @ 3:07 am
