Can someone please tell me if you can use TCV/TCCD's with the sbove soundcard!!! Please Someone!!!! I've asked this before an I never get an answer!
Cheers,
Rory!
Cheers,
Rory!
geposted Fri 01 Sep 06 @ 7:48 pm
It doesn't have 2x stereo out. So you can't use it.
geposted Fri 01 Sep 06 @ 7:54 pm
Isnt' that the pro tools sound card? , that does have 2 analog inputs and 2 analog outputs, just give it a try
Four simultaneous inputs with analog and digital I/O
Two analog inputs (XLR, 1/4" line, and 1/4" DI jacks) and two analog outputs (1/4" jacks)
Two channels of S/PDIF digital I/O (RCA)
U might need some adapters for phono though, sounds like a bunch of headaches, unless u already have it
geposted Fri 01 Sep 06 @ 8:00 pm
I saw pictures, where did you see 2 stereo outs? maybe i mist it :)
geposted Sat 02 Sep 06 @ 12:08 pm
Hmm Interesting , the descprition actually says it has 2 out's plus headphones. But it does have 2 stereo inputs and he can use the skins internal Mixer, Thats why I also said that unless he already has it, It will be a bigger headache than what it's worth
http://www.zzounds.com/item--DGDMB2
Your right I dont see where it has the 2 outs, unless the counted the headphones twice lol
geposted Sat 02 Sep 06 @ 6:00 pm
geposted Sat 02 Sep 06 @ 6:05 pm
yeh, I do already have it!! it has a L and an R out put! Could they not be used as to mono outputs and it also has a headphone output!!
I really wanted to use it wit TCV!!
Any ideas guys!
Any ideas guys!
geposted Sun 03 Sep 06 @ 6:05 am
Just try it, whats it gonna hurt to by some adapters ur gonna need a pair of
L+R Rca Female to 1/4" stereo male ( I believe your input for each "line in" is TRS 1/4" )
TRS is just a fancy word for stereo male so each Line In has stereo, after you get or make the adapters plug in your tt's into the female rca's, Im not sure if your card can handle phono inputs though
geposted Sun 03 Sep 06 @ 6:45 am
