Forum: Old versions
Topic: VirtualDJ 4.0 TC config problems
First of all I’d like to thank allot for the good work.
Id tried the version 4 out but I had some troubles with the manual channel mapping. In version 3.4 I could set up the TimecodeConfigMapChanIn under HKEY_LOKAL_MACHINE_SOFTWARE_VirtualDJ. But in Version 4 it seems to have no influence.
I need this functionality very urgent. I use the M Audio Delta1010LT and this card has two mike inputs on channel one and two. I use this channels for other apps.
A lot of thanks for a fast contact or bug fix.
Greetings da rockka
geposted Fri 01 Sep 06 @ 10:14 pm
phillydjPRO InfinityModeratorMember since 2004
Ver 4 is now in HKEY_CURRENT_USER
geposted Fri 01 Sep 06 @ 10:26 pm
Thanks a lot.
It works fine now, you are great man.
where have you this informaton get? Did I miss something?
Greetings da rockka
geposted Mon 04 Sep 06 @ 5:53 am
