Forum: Old versions
Topic: Two database files? VDJ 3.4 and 4.0
Running both 3.4 and 4.0 (simply renamed the 3.4 exe file as suggested here). both work. analysed a bunch of songs in 4.0, noticed they did not show as analysed in 3.4, then noted two database files, one VDJ database, the other VDJ database (administrator); the latter created by 4.0. Can I delete one or the other; will both 3.4 and 4.0 refer to it?
Thanks
geposted Tue 05 Sep 06 @ 1:40 am
nope.
Virtual DJ 3.4 and 4.0 uses two different databases, just as you describe.
The 4.0 database have features making incompatible with 3.4
So, you have to analyze in both versions, if you use both versions
geposted Tue 05 Sep 06 @ 1:43 am
