Forum: Old versions
Topic: Controlling Video with crossfader?
are their any other mixers out there that can control the audio and video signal in vdj other than the ecler nuo4 mixer?
I just want to be able to move the crossfader on the mixer and have the audio and video mix over at the same time.
thanks,
djmas
geposted Tue 05 Sep 06 @ 9:07 am
You could get the MK2 and/or the X Session. I use the Hercules as the video crossfader and the fader on the X Session as the main crossfader. Do a search and you will see what I am talking about, but to take full advantage go out and buy the full version of Virtual DJ.
geposted Tue 05 Sep 06 @ 9:55 am
mp3jrickPRO InfinityHonorary MemberMember since 2003
This is easily done by locking the faders in video config.
You can also set it up by changing the default keyboard short cut for audio (page up and down) to video fade.
The Xsession is an excellent mixer, the faders are a bit fragile imo. There is no way to replace them as they are permanent board mounted.
geposted Tue 05 Sep 06 @ 11:58 am
With bcd2000 is easy to mix audio and video at the same time with crossfader.
geposted Thu 07 Sep 06 @ 5:48 pm
