Hey everyone, just real quick, how do you do this after the option given upon loading stops showing up? Is there an option from one of the control panels somewhere? Please help me out. Thanks.
geposted Thu 07 Sep 06 @ 2:48 am
Itues uses its own playlist format (XML)
Convert iTunes XML playlist to normal playlists, and put inside a folder (for example VDJ playlist folder, or make a folder say called "Converted iTunes Playlist") and add to favorites inside VDJ
Use this tool to convert:
http://chimpen.com/things/archives/001450.php (small converter app)
or convert online :
http://chimpen.com/itunes2m3u/convert.php
Hope that helps;)
or convert online :
Hope that helps;)
geposted Thu 07 Sep 06 @ 7:45 am
Cool tool norway!
Didn't knew about them!
geposted Thu 07 Sep 06 @ 3:07 pm
Very useful! :)
geposted Thu 07 Sep 06 @ 3:21 pm
Wonderful ;);););)
geposted Thu 07 Sep 06 @ 5:35 pm
This didn't work for me. It says the files can't be found but the file path looks correct.
geposted Fri 06 Oct 06 @ 1:41 am
Thanks fo that.
The tracks appear in VDJ. But are we able to actually load them onto the decks ?
When using VDJ 4 for the first time it automatically transferd my itunes playlists to VDJ. Cant i do this again?
geposted Sun 15 Oct 06 @ 6:47 pm
I was trying to figure out the same thing? So can VDJ convert Itunes?
geposted Mon 13 Nov 06 @ 12:03 am
You know what's easier, create a virtual folder, then drag & drop your playlist fom itunes to this virtual folder. Also cease from downloading new versions of itunes if your current one works fine cause itunes are notorious for changing shit up for protection. This way you can create endless playlists within itunes, then just drag them over to VDJ.
geposted Mon 13 Nov 06 @ 12:07 am
So I still don't get it. I loaded vdj4 onto my computer. It asked if i wanted to sinc up my computer with itunes. And now your saying i have to create folders in vdj4 as well as itunes. then drag and drop into what. Where did you create your virtual folder and how did you drag and drop. And as for converting I only use tunes just to change all of the id3 tags but go and get Tag Scanner and you can change everything down to the filename.
So basically I want to organize my library which is mostly mine not bought on itunes. All mp3. Plus I want to use this organized library on more than one computer and want them to be the same. I run either a home machine and a moblile laptop for the clubs. So i used itunes to organize and now i want to use that library on virtual dj.
HELP
Kaustic
HELP
Kaustic
geposted Thu 07 Dec 06 @ 12:32 am
