Forum: Old versions
Topic: HELP Support hours?
jchiarPRO InfinityMember since 2005
Hi,
What are the support hours over there for trouble tickets?
VDJ gets a protection error and i cant get in after downgrading from 4.0 to 3.2 and upgradeing to 3.3...
Are they closed for the weekend? Need this for tonite and this weekend!
HELP
geposted Fri 08 Sep 06 @ 5:32 pm
xeonPRO InfinityModeratorMember since 2004
Let's do it simple: uninstal VDJ, clean the registry where VDJ leave some info and then install it again. is should work. Otherwise there is e-service.
geposted Fri 08 Sep 06 @ 6:06 pm
yeah tried to uninstall. delete any found registry keys. and then installed 3x..
No good this way, but thanks.. unless there is a uninstall cleaner??
geposted Fri 08 Sep 06 @ 6:22 pm
