Forum: Old versions
Topic: vdj4 doesn't work like the vdj3
LocutosPRO InfinityMember since 2003
Hello! I used to work with the vdj3, the latest version before vdj4 and I had the software plugged in to an external mixer, so as you can imagine my soundblaster (creative by the way) 4.1 has 2 outputs! Before I could mix using only my external mixer, because the crossfader of the mixer of vdj was on the center and like so it worked!!! But not now! I am ksick off trying all the different sound configurations but it stil gives me the sond off the two musics mis on one chanel! Please help! Sorry about my english!
geposted Mon 11 Sep 06 @ 9:32 pm
DJ-ALFPRO InfinityModeratorMember since 2005
HI
I am not sure what is your problem with V4, but I have SB Live USB and it works with external mixer. You should setup like this:
If you using external mixer:
Outputs:External Mixer
Sound Card(s):4.1
Front output is left deck, Rear output is right deck.
If you don't use mixer than:
Outputs:Headphones
Sound Card(s):4.1
Front output is Master out, Rear out is your headphones.
Leave the crossfader centered on the VDJ and on your external mixer.
geposted Tue 12 Sep 06 @ 4:00 am
