Forum: Old versions
Topic: laptop specs ok for vdj?
I've been driving my self crazy because I want to get up & running with vdj using it to mix my videos.So here is what I can get can anyone tell me if this will work good to do mp3 & vob files but more to do video?
specs for new laptop:
Intel Core Duo t2400 1.83 GHz(667 MHz)dc 2mb cache yonah
2gb ddr2 667MHz sodimm memory cl-4
100gb western digital 5400 rpm hard drive
ati radeon x1600 video card w/256 mb memory (Not Shared w/others)
Microsoft windows xp home edition
Can you please let me know if this will work hopefally without any glitches?
PS.
I know once I get up & going I have to play with the setting,as long it is just that not that the computer not good.
geposted Tue 12 Sep 06 @ 12:22 am
I think that laptop will be much more than adequate for VDJ.
I use a rackmount PC, but i have a Dell Laptop for backup, which has a 2ghz celeron processor, 256 ram, onboard sound and video.. and it runs VDJ 4.0 just fine.
geposted Tue 12 Sep 06 @ 1:42 am
DJ-ALFPRO InfinityModeratorMember since 2005
This laptop is all you need for video mixing. You have to get usb sound card, I recommend ESI U46DJ or Hercules MK2.
geposted Tue 12 Sep 06 @ 4:43 am
DJ CyderPRO InfinityModeratorMember since 2003
I agree the specs are ok to run video with however i've not personally tested.
geposted Tue 12 Sep 06 @ 5:21 am
acw_djPRO InfinitySenior staffMember since 2005
good equipment, videos will run very good with this...
Good Choice ;-)
geposted Tue 12 Sep 06 @ 8:58 am
Well I got the new laptop that I had put the specs to see if it would work & it does but the audio output sounds bad,what I mean by that is that the highs are way too high.I tried to play with the eq but doesn't help.I'm using 3.4 because I saw too many bad post on the forum about 4.0.I'm using usb gigaport ag as my sound card vob files ripped w/the vdj ripper the sound plays fine through wmp but when I play it through vdj3.4 it sounds pretty bad . Is there anything that I can do.
geposted Mon 18 Sep 06 @ 2:18 am
