Hi everybody!
Trying to use my D-Vinyl controller with VDJ4, the program seems not to recognize the controller at all. The D-Vinyl option is checked on the remote control tab in the config. Is there anything else to do? In VDJ3.4 it works without any problems...
Has anyone already used the D-Vinyl controller with the new VDJ Version?
Thanx!
triad
Thanx!
triad
geposted Tue 12 Sep 06 @ 8:34 pm
I dont have or use the d-vinyl, but the only i can think is that maybe the dll files (mapper) for this controller are missing from your vdj 4.0 installation folder, (maybe they are missing from the installation file too), so check for "D-Vinyl2020A.dll" and "D-Vinyl2020A.dll" files in your vdj 4 folder. If they are missing copy them from your 3.4 folder (assuming that you have both installed in different folders)
Let us know if this work for you.
geposted Tue 12 Sep 06 @ 10:57 pm
Hi apopsis
The DLLs were the problem! After copying them to the new VDJ4 folder the controller works without any problems! Great! :-)
THANK YOU very much!
triad
PS: the same problem might be with other mapper dlls too...
triad
geposted Wed 13 Sep 06 @ 8:10 am
glad to help !
geposted Wed 13 Sep 06 @ 2:00 pm
effect buttons don't work anymore ont the controller. Can U make it work again?
geposted Sat 16 Sep 06 @ 5:22 pm
