Topic: Virtual Dj 1.9 Data Base
I have been a long time user for Virtual DJ 1.9 souly because I cant get my VDJ 1.9 database to load on Virtual DJ 2.1 or higher!
I have over 120GB of songs with various cue point, and it would be real hard to sit and cue them all over again after I upgrade. Is there a way around this or do I have to clear me schedule and start the agonizing task of cueing them over again?
geposted Wed 13 Sep 06 @ 5:46 pm
phillydjPRO InfinityModeratorMember since 2004
Maybe If you buy the software it will work great and you can get the support needed,
But maybe I'm wrong and you have bought the software In which case please enter your serial in your profile so that we may better help you.
geposted Wed 13 Sep 06 @ 6:03 pm
Yes, please write your product details here
geposted Thu 14 Sep 06 @ 10:36 am
sbangsPRO InfinityMember since 2004
yes
sounds fishy to me
geposted Thu 14 Sep 06 @ 8:54 pm
remember vdj 1.9 was included with the original HDJC and he may not have purchased it here at this site. this was my problem once too, since my first vdj version was the one included with HDJC and i showed up as no license user. i only showed up as valid user after i purchased the full version.
geposted Fri 15 Sep 06 @ 1:01 am
hmm i was nonlicence but had a DJC icon under my name.
That's the difference, usually it's enough to detect it, but anyway
1.09 is ok, what about 2.1 :-) ? it's not the console version for sure.
Try the demo of v4, it should import the database hopefully.
But BACKUP the database before any installation (backup recoomended on regular basis)
geposted Fri 15 Sep 06 @ 4:10 am
