Topic: Bad noise and crackles [solved]
Hello, my name is Alex. And i have a big Problem with VDJ 4.0 . I looked up in much forum posts but there were no that helped me. The Problem: When i use the faders and equilizer-buttons in the software i hear bad noises and crackles and i don't know where they come from. This Problem wasn't in VDJ 3.4 .
My System:
Athlon 3500+
1024 RAM
Sound: RealTek ALC850 8-Kanal Software Codec (Onboard Soundcard) - i use the coaxial output
and when i use the Hercules DJ Console MK2 i have the same problem...
i have the newest drivers, active USB 2.0 Hub and optional Power-In
So, when somebody has an idea and could help me, i would be very pleased.
Greets from Germany,
Alex
geposted Thu 14 Sep 06 @ 6:22 pm
TexZKPRO InfinityMember since 2005
geposted Thu 14 Sep 06 @ 9:07 pm
THAAAAAAAANKS A LOT!!!!! IT WAS THE HELP I NEEDED! THE BAD CRACKLES ARE AWAY!
THANKS! THANKS! THANKS!
geposted Thu 14 Sep 06 @ 11:22 pm
But which part of all that advice fixed it for you Laserman?
geposted Fri 15 Sep 06 @ 3:18 am
That I "DEACTIVATED the SAVE MODE" and "ACTIVATED the OVERCLOCK".
geposted Fri 15 Sep 06 @ 12:50 pm
No problem, I've crashed my head for a whole week before discovering these options were my death with my Mk2. Then I realised there already was a topic about that, but the info was a bit hidden, so I made a stand-alone topic.
geposted Fri 15 Sep 06 @ 8:03 pm
