Forum: Old versions
Topic: What's those buttons for...?
djmmHome userMember since 2004
I am wondering what the two buttons under the stick on the DJ Console are used for in Virtual DJ. I press them a number of times but they don't seem to do anything. What are they for?
geposted Fri 09 Jul 04 @ 10:28 am
SPARKYPRO InfinityMember since 2004
The stick can be used as a mouse, and the 2 buttons are used as mouse buttons (left and right)
Just enable the mouse in the hercules conlsole pane; (not in virtual dj itself)
geposted Fri 09 Jul 04 @ 10:33 am
HEY!
THANKS AGAIN!
DJ MM
geposted Fri 09 Jul 04 @ 10:39 am
djbambiPRO InfinityMember since 2003
also, if you use the joystick to select the songs in your playlist, left button loads deck A, right button loads deck B. therefore, no need to use the mouse to load tracks...
geposted Fri 09 Jul 04 @ 3:18 pm
Cool. ;)
geposted Mon 12 Jul 04 @ 10:18 am
