Forum: Old versions
Topic: VDJ4.0 Not Playing at All
djrandyPRO InfinityMember since 2005
I have VDJ4.0 installed, the program loads, I can load a song onto a deck, but it will not even play....I need assistance. I have it set to the internal sound card just to play with it. I have tried changing the setting in the config menu....NOTHING! I am getting frustrated!
Any suggestions?
Randy
geposted Wed 20 Sep 06 @ 1:54 am
listen2PRO InfinityMember since 2005
what setup do u have? pc specs and hardware used?
geposted Wed 20 Sep 06 @ 5:04 am
DJ CyderPRO InfinityModeratorMember since 2003
check to be sure you don't have time code enabled unless you are using time codes, the inputs should be set to none.
geposted Wed 20 Sep 06 @ 5:31 am
