Hi guys I'm looking to buy a laptop just for VDJ and all the music and nothing else. Can you give any input .thanks Phil
geposted Wed 20 Sep 06 @ 12:59 pm
The minimum requirement to run Virtual DJ is:
PIII 850 MhZ computer
1024x768 SVGA video
DirectX compatible soundcard
512 MB RAM
20 MB free on the hard-drive
The recommended configuration is:
PIV 3 GhZ computer
1024x768 SVGA video
4.1 DirectX compatible soundcard (with front and rear separate outputs)
1024 MB RAM
200 MB free on the hard-drive
1024x768 SVGA video
512 MB RAM
PIV 3 GhZ computer
1024x768 SVGA video
1024 MB RAM
geposted Wed 20 Sep 06 @ 1:26 pm
geposted Wed 20 Sep 06 @ 1:42 pm
Thanks XEON how many songs you think can fit on that hard drive without slowing it down
geposted Wed 20 Sep 06 @ 1:58 pm
The hard disk are slowing down when you get over half of it's size but it is not so bad in new models with big cache memory (16Mb model).
geposted Wed 20 Sep 06 @ 2:05 pm
DO you guys have a favorite PC brand and model that i can look into
geposted Wed 20 Sep 06 @ 2:09 pm
well.. i have one :D Apple MacBook PRO :P
But you'll have to wait to VDJ 4 mac ;)
But you can buy any pc that has good components (fast disc & ram, core duo processor, good graphic card, possibly ATI,...)
geposted Wed 20 Sep 06 @ 2:12 pm
I have an LG 1.7 Centrino and VDJ works no problem! I'd recommend LG or SONY VAIO if its in your budget!
geposted Thu 21 Sep 06 @ 7:31 am
For audio maybe. If the specs I've been told to go with for a desktop to run viddeo I don't think they make a laptop powerful enough for video!
geposted Fri 22 Sep 06 @ 5:18 am
Hi,
VDJ will work better on a computer with dual core... ;)
geposted Fri 22 Sep 06 @ 4:01 pm
