Right, I have 2 Numark TT1650 Turntables, The original DJ Console from Hercules (Being replaced next week), 2 TCV's, and my laptop (and yes, I will be purchasing VDJ pro in 2 weeks so save the smart-assery on that). When I activate the TCV and ASIO settings, I get no sound from the laptop speakers, but only from the headphone jack on the djconsole and the outputs on the djconsole. Is that normal? or is there a way to define which speakers I want to use as the outputs? I will be using the setup as part of a show car setup with a pc mounted in the back of my SUV.
geposted Sat 23 Sep 06 @ 9:10 pm
the console is a replacement sound card
that is its purpose lol
btw have u bought pro yet , na only messing :D
geposted Sat 23 Sep 06 @ 11:11 pm
I know that it is a second card, but is there a way to have the sound return to coming from my laptop while in ASIO mode.
geposted Sun 24 Sep 06 @ 3:48 pm
Bueller...anyone... anyone have an answer to this?
geposted Wed 27 Sep 06 @ 1:42 pm
If you are using the hercules as a sound card, it's normally that you don't listen anything from your laptop speakers because they are conected to your internal sound card. If you want to listen the master on your laptop speakers you must conect the line-out of your console to the line-in of your laptop souncard ( or mic-in if it's stereo).
geposted Wed 27 Sep 06 @ 4:29 pm
