Forum: Old versions
Topic: Friendly Behringer BCD2000 users.... - Page: 1
jeemmHome userMember since 2006
Hey..I have posted like 3 topics about BCD 2000 and VDj. Every time only 1-2 people responded...I am considering buying a BCD2000 but I have huge question marks in my mind.
1.First of all does it work OK with VDJ( VDJ 3.4 or VDJ4.0 ) .
2.Secondly, how does it feel...Is it a nice thing to buy or is it just waste of money?
3.If you have ever used Hercules MP3 Control DJ, can you compare these two products...(Hercules looks like a childish toy to me)
Of course i am aware of the fact that you cant get the same quality from a $200 product where there are ones worth + $1000...I am not able to afford that much money and most of the time places I play have their systems so I dont need this...But still sometimes I need my own system....=D
Thanks in advance. I will me waiting for your replies...
geposted Sun 24 Sep 06 @ 6:36 pm
plawer8Home userMember since 2006
A friend of mine recieves his BCD 2000 next week. I'm going to try it next to my Hercules DJ Console MK2. It will probably be sometime next week.
If you have any plans regarding using TCV's then the BCD isn't an option. Having the option to use two inputs and two outputs (master/headset or turntable 1/2) on the Hercules is the reason why I chose that.
geposted Sun 24 Sep 06 @ 6:44 pm
hi there
i have a behringer bcd2000 and virtual dj v4 pro on my p4 1.7ghz lap top, and its running excellent.
with the help of few djs in virtual dj forum, we have managed to get all buttons working, headphones pre cue on each deck in vdj v4 software working great,
plus behringer has an ac mains plug to power it making it better with no power problems, all buttons are fully re-programmable, the sound level output is very high on headphones and master output and it can be used as an external sound card too.
ive checked out the hecules dj console mk2 and its got too many little problems with vdj v4 at the moment, and less programmable buttons
behringer looks more like a real mixer and can be used as a real mixer because it has line and phone inputs for cds or turntables
i have also managed to get tccd's (time code compact disks) in my pioneer800 to work with bcd2000 and vdj v4
and if behringer make a mk2 version next year, it could change the whole djing world! Lol
hope this info. helps?
geposted Sun 24 Sep 06 @ 8:50 pm
moramaxPRO InfinitySenior staffMember since 2005
geposted Mon 25 Sep 06 @ 9:30 am
i bought a bcd2000 yesterday.
i didn;t get asio driver to work. also i couldn't headphones to work with vdj either.
the direct x driver works just fine. the sliders on the bcd2000 respond real fast with vdj, but still no correct headphones control. the headphones do work, but only on channel 1-2 not on 3-4.
i will try the above posted links in order to get them to work.
the look and feel of the console are positive/robust. good quality/price.
until there is no correct headphone control, i will have to use an external mixer.
geposted Mon 25 Sep 06 @ 11:01 am
geposted Mon 25 Sep 06 @ 12:23 pm
spoonieHome userMember since 2006
I can't find the solution for BCD2000 ASIO in the blog (only tutorials for corrupted database and current noise)
geposted Mon 25 Sep 06 @ 1:34 pm
spoonie i'm sorry but the tutorial is accesible for only professional user accreditation.....and now you are a no-license user.
geposted Mon 25 Sep 06 @ 2:55 pm
@DJcannonball
If you want you can contact me for a better help, is not neccessary an external mixer for headphones, regards.
geposted Mon 25 Sep 06 @ 6:56 pm
ouch.. so, people here will not help anyone who is not yet a registered pro user?
my situation is like this, the reason why i would like to buy vdj is because i want to
use timecode vinyls. i have a bcd2000+2turntable+laptop. i just placed my order
for 2 timecode vinyls (order# E1019014).. now, i would like to personally test the
timecode vinyl on my setup using vdj 4.0 eval.. if i don't get any problem, i will
purchase the pro version asap.. $299 is a big money.. and i just want to make
sure everything is running ok before i commit my hard-earned $$$ to vdj...
hey, DJiN.. are you still willing to help me?... or maybe, when i get my timecode
vinyls...
cheers to bcd2000 users...
~bunnymen
geposted Tue 26 Sep 06 @ 10:10 am
DJ-ALFPRO InfinityModeratorMember since 2005
You can download V4 demo here and it has all functions just limited on 20 days so you can try your TCV's. People here will help you, only the ones who uses crack will not get support.
geposted Tue 26 Sep 06 @ 10:13 am
We will help you ;) no need to worry :)
geposted Tue 26 Sep 06 @ 6:11 pm
thanx peepz, i was struggling with the asio-driver (i keep getting those messages when selecting asio: ASIO-ERROR). the solution was simple. in configuration, tab-performance.. the slider had te be absolute most left, and the latency has to be set to AUTO.
then.. suddenly the asio-driver began to work :-D even with headphones!
geposted Wed 27 Sep 06 @ 2:08 pm
Using two inputs would AFAIK require the full version anyway. The problem with the headphones out is more bacause VDJ v4 does not have an easy way to assign separate ASIO outputs like most other DJ software does. This is said to be addressed in the next update. Also this would require the full version anyway.
geposted Tue 03 Oct 06 @ 4:38 pm
Hi, a have a Hercules Dj Console, and finally, this is a toy...! so i bought a BCD2000 and i'm waiting to recive it this week.
I have the version of Virtual dj, that comes with Dj Console, so i'm am not a professional user, but i paid for this version... and like other people, i want to be sure that all works, the new bcd2000 and also the 2 time coded vinyls i bought in your web.
So, how can we do, to see the tutorials and blogs, only for "professional users" ?, when i only want to test everything before buy the new version of Virtual Dj..
Can you send it to me by e-mail ¿?
Thank you for all, and congratulations for your work.
geposted Tue 03 Oct 06 @ 7:16 pm
afaik you will need to upgrade to the pro version anyway..
geposted Fri 06 Oct 06 @ 6:37 pm
djkollado
you need to update to pro version for accesing to blogs, most of them are only for registered users, regards.
geposted Fri 06 Oct 06 @ 7:46 pm
oppofixHome userMember since 2006
Hi everybody.
I'm a VDJ user with BCD2000, and for me this union
could be ok. I say "could" because with VDJ3.4 i use
correctly the TimeCode Vinyl, but with the VDJ4.0 PRO it doesn't work!
Strange but true.
The problem is that VDJ3.4 recognises the 4 input / 4 output channel
of the BCD2000 (2 stereo input, two stereo output), but with the version 4.0
compares the message "Asio channel not enough".
I use the configuration with "BCD2000-Asio" driver and 2 Timecode Vinyl; i even tried to use
the "Asio4All" software, but only 2+2 channels are recognised.
Can you help me? It's a problem for me, because i purchased the VDJ4.0
just because i've seen 3.4 working fine and i tought that with 4.0
it would have been even better...
Bye from Fabrizio (Italy)
geposted Sat 07 Oct 06 @ 6:22 pm
Interesting you can do all this wit the demo version. Or did you forget to enter your VDJ serial?
Or maybe you're just talking bs..
geposted Sat 07 Oct 06 @ 6:37 pm
oppofix
You should consider getting the license, you will love this forum much more :)
geposted Sat 07 Oct 06 @ 7:35 pm
95%
