its won't let me save the ripped vinyl as an mp3, it also doesn't give me any other options as to what i can save it as...any suggestions????
geposted Sun 24 Sep 06 @ 10:55 pm
have you located the Lame codec its thefile which makes mp3 conversion possible to get it
look for lame enoder .dll in the program folder if its not there look
on google
download it and place it in the main program folder of VDJ
then all should be well :)
on google
geposted Mon 25 Sep 06 @ 11:50 am
yea i've done that like twice and it still says impossible to save...because when you go to congifure, you press the little dots rite noext to the bit rate and thats where you select the lame encoder but it keeps tellin me impossible to save the file name*.mp3
geposted Mon 25 Sep 06 @ 1:56 pm
can you save it as a wav file?
if so , convert it later
geposted Mon 25 Sep 06 @ 2:46 pm
no it doesnt give me the option to save it as anything but mp3....
geposted Tue 26 Sep 06 @ 12:07 am
try a reinstall?
geposted Tue 26 Sep 06 @ 9:30 am
