was playing about with vdj 4.0 today remapping different buttons on my mk1 console when bam, vdj shut down with a serious error or something.
Started vdj again then i get the following message.
Internal database corrupt.
followed by
The skin you trying to use is to high a resolution for your screen (summut like that)
Vdj still works but all of my settings have changed to default.
All of my Bpm and track lengths have dissapeared for each track i have.
WTF has happened?
I re installed vdj 4 but it still says the same mesages.
I rolled back my computer to 2 days ago and still corrupt database.
Any help would be great.
followed by
WTF has happened?
geposted Mon 25 Sep 06 @ 5:57 pm
also i went back on vdj..scanned a few tracks and the bpm and track lengths came up as normal.
Shut down vdj then went back on.
Still it said corrupt database and the songs that i had scanned and analysed no longer had there bpms and track length.
geposted Mon 25 Sep 06 @ 6:19 pm
Your database is corrupted and you need to remove it from VDJ folder and than it will create a new one. It is "Virtual DJ database.xml" file, don't delete it, somebody here can help you to repair it, just move it on some other location for now so you can use VDJ. It happend to you because of crash or VDJ wasn't closed correctly. Dev team should make some Tool for repairing corrupted database because it is a little error in file.
geposted Mon 25 Sep 06 @ 6:40 pm
ah tks for the info and quick response.
I have removed the file and put it onto my desktop for the time being.
Vdj struck up and worked fine after that.
If anyone can help me repair the file in same way please help me ..tks
geposted Mon 25 Sep 06 @ 6:45 pm
geposted Mon 25 Sep 06 @ 7:10 pm
ty for the link.
sounds complicated but i will give it a try. tks
geposted Mon 25 Sep 06 @ 7:47 pm
What program do i open it with?
the xml file that is so i can edit it
geposted Mon 25 Sep 06 @ 8:25 pm
notepad, or even better, some free XML editor. Just Google:)
geposted Mon 25 Sep 06 @ 8:31 pm
Wow u guys are good.
Got my database back and is working fine once again.
Ty for the support.
Made sure i copied the xml files Heh :<
Ty for the support.
geposted Mon 25 Sep 06 @ 10:24 pm
Glad you sorted it out ;)
geposted Tue 26 Sep 06 @ 2:17 am
