Forum: Old versions
Topic: laptop+bcd2000+2xturntable+timecode vinyl+vdj4.0 (eval)
Hi DJiN.. this is just a follow-up re: my post in b-dj forum...
>> thanks for the info.. i will be doing beatmixing only, no scratching - im
>> more like a bedroom dj.. i hope you can post a detailed setup/wirings.
>> or if you can point me to an online link which has a detailed setup using
>> bcd2000+2xturntable+laptop+timecoded vinyl.. thx again.
i just placed my order for 2xtimecode vinyls in your shop (order# E1019014).
i would like to try this first using vdj4..0 eval version. if everything is working
ok, i will be purchasing the pro version asap.
cheers,
bunnymen
geposted Tue 26 Sep 06 @ 9:49 am
xeonPRO InfinityModeratorMember since 2004
nice!
be sure it will work, otherwise, here is a forum ;)
geposted Tue 26 Sep 06 @ 10:23 am
acw_djPRO InfinitySenior staffMember since 2005
We can help you to evaluate your hardware with VDJ and TCVs, don't worry.
geposted Tue 26 Sep 06 @ 10:36 am
cheers,
bunnymen
I remember you on Xylio forum, and Iam glad to see you here, you will se that everything will be clear now and do not worry we will help you to set up your things
regards
Dj Quintana
geposted Tue 26 Sep 06 @ 4:07 pm
No worries;)
You're at the right place, and we'll help you :)
Good to see you here...
geposted Tue 26 Sep 06 @ 6:10 pm
