Forum: Old versions
Topic: Cant rip DVD's
I thought i might try using videos at my shows, but i can't rip with the VJD dvd ripper. If the disc is already in the drive when i turn on the ripper, then it crashes immediatly. If i put a dvd into the drive after the ripper is open then it crashes when i press the rip button. I am using 4.0 but had the same results with 3.4
Any ideas?
My home PC is an Emachines T3410
AMD semprom 3400+
512 ram, XP Home
Lite-On DVD combo Drive
geposted Thu 28 Sep 06 @ 2:07 am
Anybody have any idea's. This is the only PC i have with DVD drive in it
geposted Sat 30 Sep 06 @ 5:59 pm
Do a search for Smartripper. It is a great and easy to use app to Rip. Check it out on this forum cause there have been many conversations about it. Also it was talked about a lot in DJCHAT.
geposted Sun 01 Oct 06 @ 1:29 am
