Forum: Old versions
Topic: Headphones working?
I have VDJ and I need to know how to listen to the track that I'm queing up while the track is playing through my speakers. Do I need a certain kind of sound card? I'm nunning an input into a 2 channel mixer and I want to also know if I can use vinyl from you guys to mix like I used to do with my Final Scratch?
Any help is greatly appreciated.
geposted Thu 28 Sep 06 @ 3:54 am
xeonPRO InfinityModeratorMember since 2004
You need 2 outputs at sound card and full PRO version of VDJ to prelisten.
geposted Thu 28 Sep 06 @ 7:09 am
phillydjPRO InfinityModeratorMember since 2004
It's only possible with the demo version of 4.0 (beside the Pro versions of course)
geposted Fri 29 Sep 06 @ 7:07 pm
AMBUSHHome userMember since 2006
I am experiencing the same problem so need to know how to get 2 outputs from my Soundcard.
Even if I do will I be able to hear the cued track if i'm using the latest trial version.
thanks in advance
geposted Fri 29 Sep 06 @ 11:21 pm
