I own a PC and have a soundcard which i know will work with the Timecode Vinyl's but my aim is to have them working with my Laptop.
So, i was wondering if it is possible to upgrade Laptop Soundcards?
I own a Medion MIM2080 Notebook PC which really doesnt have a very good soundcard.
What im wanting to do is, id like to upgrade it to a soundcard which would let me plug in my Turntables (which is done through a Line-In socket on good soundcards) so i can then use the Laptop for DJing but, i have no idea whether or not it is possible to upgrade the soundcard, i have no idea where to find these upgrades and i have no idea how to install them...
Thanks in advance.
Thanks in advance.
geposted Thu 28 Sep 06 @ 7:46 pm
Buy external USB soundcard like U46DJ and it will work ;)
geposted Thu 28 Sep 06 @ 8:20 pm
Thanks mate. Is this the hardware you mean? http://www.floridamusicco.com/proddetail~prod~u46dj.htm
And if so, is there a place to get it cheaper or is that best price ill be able to get it at (jus curious as im only 16 earning hardly anything by the hour. lol!)?
geposted Thu 28 Sep 06 @ 8:33 pm
Yes, that's it. If you are from EU you can try at www.thomann.de
geposted Fri 29 Sep 06 @ 12:22 pm
And remember of the Demo's only the demo version of 4.0 will let you play around with sound card configirations
For everthing else theres Pro
geposted Fri 29 Sep 06 @ 7:27 pm
