Forum: Old versions
Topic: Help needed U4DJ card,
HoffmanPRO InfinityMember since 2006
Hi,
brand new DELL 1710 XPS. 4.0 pro, used the software on the laptop for about 10 hours today- great.
Now it was time to hook up to the soundcard, TCCD, cd players, mixer, etc etc etc.
I have nothing but a very annoying loud buzz- it goes away when I remove the USB cord or unplug the rca's going to the mixer.
I am ready to trouble shoot.
Thank you!!!!
geposted Fri 29 Sep 06 @ 5:51 am
DJKicePRO InfinityMember since 2005
I would beleive my friend it is a grounding issue. Try using a balanced transformer.
geposted Fri 29 Sep 06 @ 3:50 pm
rEsKPRO InfinityMember since 2006
The buzz is the timecode signal. Open the esi mixer on the taskbar and push monitor's mute ("m" behind the faders).
geposted Tue 03 Oct 06 @ 12:56 pm
that problem has been solved- thank you/
geposted Wed 04 Oct 06 @ 4:11 am
