Forum: Old versions
Topic: VIDEO Laptop hookup help needed for tonight.
HoffmanPRO InfinityMember since 2006
Hi,
if this works for tonight it will be a miracle.
I want to hook up my laptop with VDJ Pro 4.0 to sen out video.
If I come out of it with S video, or DVI or VGA, the person at the computer store told me, whatever i have on the laptop screen will be sent out. Is this true? Is there a setting in VDJ or does it just know?
How do I send only the video/visuals and not have the people see what I see on the laptop?
Also my DELL XPS 1710 came with a STUPID 7 pin s video instead of 4 and this is making for a nightmare of a time trying to convert.
Any technical help is soooooo needed for tonight.
Thanks!
geposted Sat 30 Sep 06 @ 11:04 pm
phillydjPRO InfinityModeratorMember since 2004
I answered your question in the general forum, as far as i remember though you can plug a 4 pin svideo into the 7pin slot and have no problems
I do a 7pin to composite (rca) with a 4pin to composite adapter and it works fine
geposted Sun 01 Oct 06 @ 12:00 am
Thanks Phily, I will try it tonight, but I just realized,
How is that that people at the club do not see what it is on the laptop (VDJ) and only the video that gets sent to them?
B
geposted Sun 01 Oct 06 @ 12:08 am
once you enable the second monitor through windows, it uses dualview it does not clone your primary monitor
Unless you want to clone your primary monitor and let them see VDj in which case you would have to go through your Video cards software and enable clone
geposted Sun 01 Oct 06 @ 2:48 am
