Forum: Old versions
Topic: This is weird..please help (video)
HoffmanPRO InfinityMember since 2006
HI,,
This is weird,
I am using an XPS 1710M laptop for music and video at the club. New Nvidea 7900GTX 512 mb video card. power!!
I must be doing something very wrong, becuase on the plasmas around the club, I was somewhat successful (not totally) in getting the screens to only show the output video, but MY CURSOR was showing up on the plasmas when I moved it on the laptop.
has anyone ever heard of or seen this probelm and can help?
Why would my white cursor appear over the video that is playing to the audoence..
THanks.
geposted Sun 01 Oct 06 @ 8:38 pm
Part II
When the curser shows on the Laptop it does not appear on the plasma screen.
When the curser appears on the plasma, it does not appear on the laptop.
Here's a pattern...
Maybe if the mouse goes off the VDJ screen area- this could have an effect. I have my resolution at 1280 x 800 as to not maximize VDj on my laptop.
Any thoughts?
geposted Sun 01 Oct 06 @ 10:00 pm
PionaraPRO InfinityMember since 2004
Hoffman, I don't use video but have been mucking about with video settings for karaoke. I use a 6600gt and I'm sure there's something like "Allow Crossover" on the Nvidia settings menu, which basically means that when you go off the laptop screen with the mouse, it shows up on the plasma screen display.
Disabling 'Allow Crossover' (or whatever it's called) stops this from happening if i remember correctly.
This is just from memory, so hopefully it's of some use.
Cheers...and keep spinnin'...(",)
P
geposted Sun 01 Oct 06 @ 11:27 pm
