Forum: Old versions
Topic: can u use 2 channel mixers?
logic54Home userMember since 2005
I have 2 technics 1200 turntables. I have a 2 channel vestax mixer. Will I be able to use time coded vinyl with that? From what I understand its just two outputs and 2 inputs. However on the how to use timecoded vinyl on this site min. requirments say u need a 3 channel mixer. Any help would be great. Thanks.
Dj Mike
geposted Mon 02 Oct 06 @ 11:55 am
xeonPRO InfinityModeratorMember since 2004
You don't need 3 chan mixer. You need sound card that has 2 stereo inputs and 2 stereo outputs. And mixer with 2 stereo inputs, so 2 channel mixer - that's all. I am sure you can connect yout Vestax mixer to use with TCVs.
but to use 2 turntables you need PRO version of VDJ too.
geposted Mon 02 Oct 06 @ 12:32 pm
Can I use two sound cards with 1 input and 1 output in each? All I need is the pro version and two timecoded vinyls? I have one sounds card that came with my mobo its a pci express audio and I have an additional sound blaster live.
Dj Mike
geposted Mon 02 Oct 06 @ 6:54 pm
rEsKPRO InfinityMember since 2006
The third mixer's channel is used for the loops
geposted Tue 03 Oct 06 @ 12:19 pm
Dj Mike
not sure about it. never tryed, but you won't get minimal latency with standard soud cards. Rather buy u46dj and you will get great combination with very low latency with ASIO drivers.
And 2 TCVs and PRO VDJ yes :)
geposted Tue 03 Oct 06 @ 1:47 pm
Can you bring out loops to separate channel??? Did you mean samples?
i use 3rd output at DJC MK1 for samples and AUX in at mixer (i have 2 chan mixer too).
geposted Tue 03 Oct 06 @ 1:49 pm
Yes, sometimes i write without think :)
Sorry
geposted Tue 03 Oct 06 @ 3:41 pm
geposted Tue 03 Oct 06 @ 3:47 pm
