Forum: Old versions
Topic: Hercules DJConsole MK2 & VirtuaDj 4 Pro
JlaraHome userMember since 2006
Hi there, Im using virtualdj and hercules dj console since 3 years ago, i get the new MK2 console and try the pro version of virtualdj 4, all works good except that I can not select the audio source to my headphones, I mean i can not listen the next song, just the actual one, anyone can help?
geposted Wed 04 Oct 06 @ 6:07 am
rEsKPRO InfinityMember since 2006
Search in the blogs for an answer.
Good luck
geposted Wed 04 Oct 06 @ 11:19 am
ciocePRO InfinityMember since 2004
geposted Wed 04 Oct 06 @ 11:35 am
my mistake sorry first time user
geposted Wed 04 Oct 06 @ 6:16 pm
Hi there, the problem stills i just want to select the headphone source whit the headphones connected to the dj console, has a button to select betwen deck a, deck b, mix, & split modes to the headphne
Thanks Again
geposted Wed 04 Oct 06 @ 6:51 pm
icarasHome userMember since 2006
hello,
i have the same problem and the link you've posted doesnt help :(
geposted Sat 07 Oct 06 @ 9:23 pm
Reinstall the pc's audio drivers - i solved that problem with this way in my laptop.
geposted Tue 10 Oct 06 @ 12:27 pm
