Forum: Old versions
Topic: URGENT, PLEASE HELP!!!!
I CAN'T GET THE VIDEO FUNCTIONS TO WORK PROPERLY ON VERSION 4.0. I CAN'T DISPLAY TEXT & I CAN'T SHOW MY LOGO. WHY? WORKS PROPERLY FOR ME IN 3.4, BUT NOT IN 4.0. I READ THE EFFECTS PAGE IN THE USER GUIDE AND IT OFFERS NO HELP.
COULD SOMEBODY PLEASE HELP ME????????
WOLFMAN
geposted Fri 06 Oct 06 @ 10:31 pm
phillydjPRO InfinityModeratorMember since 2004
It was a problem in 4.0 , it has been discussed in plenty of forums will be corrected for 4.1 release
you have to go to the effects section of the browser to activate/deactivate the effects
4.0 doesn't do the auto bitmap correctly when theres audio only files
geposted Fri 06 Oct 06 @ 11:35 pm
that's interesting, mine works fine on 4.0, are you sure you have a ll the directx and codecs installed?
geposted Fri 06 Oct 06 @ 11:39 pm
He's talking about the "show when no video or karaoke is available"
It use to turn on a image when there was no video or karaoke showing
geposted Fri 06 Oct 06 @ 11:40 pm
Its better to wait for the 4.1 update , it should be corrected by then . If you can't wait then just type the word slideshow in the box thats empty, and run over to the effects tab in the browser to choose your image
geposted Fri 06 Oct 06 @ 11:44 pm
AHH i see
geposted Sat 07 Oct 06 @ 12:04 am
sbangsPRO InfinityMember since 2004
geposted Sun 08 Oct 06 @ 10:00 pm
