HI to all:
I discovered a way to put the song names to my resulting Mp3 mix.
When you clik on "configuration" in the "rec bottom" there are several options. Just click on "multiple files" and the result will be a series of files, each in a sequential order.
Example:
Imagine you made a mp3 mix named "best varios hits" with 3 mp3 in a row on it.
Your recorded archive will be:
"best various hits001"
"best various hits002"
"best various hits003"
Now, with any mp3 editor (I used Nero) you carefully paste in a secuence this files, changing manually the names or the IDtags.
Best regards
Bahique
Example:
Best regards
Bahique
geposted Sun 08 Oct 06 @ 11:39 am
