Forum: Old versions
Topic: Does Virtual DJ re-caliber by itself ?
Hi, I would like to know if it's necessary to re-caliber virtual dj everytime you use it with different turntables to play with timecoded vinyls?
I heard that Serato Scratch do the job by itself, and I really have to know this before buying hercules mk2 w\ virtual dj, because I don't have time to caliber the software in front of the crowd, you just have to plug n play!
Thanks for the help
geposted Mon 09 Oct 06 @ 1:41 am
apopsisdjPRO InfinitySenior staffMember since 2003
Not by itself, but there is a "auto-config" button in timecode settings wich does this (set levels etc) and you need just 10 seconds to open options and press it.
I do this even on the fly, (it is safe) when i use tccds. You don't need to restart the software or anything.
Just an advice: if timecode/tcv is the way you work get virtual dj full and a better soundcard. Hercules may do the job but its not the best option.
geposted Mon 09 Oct 06 @ 4:08 am
What if I just leave this "auto-config" option always avaliable? Wouldn't it solve the problem?
Which external sound cards would you recomend as a good option to use with timecoded vinyls?
Thanks a lot
geposted Mon 09 Oct 06 @ 4:20 am
i would reccommend u46 dj works great with time coded vinyl
geposted Sun 26 Nov 06 @ 3:40 am
