Forum: Old versions
Topic: Internal Database Corrupted / Muffled Sound
mariocPRO InfinityMember since 2006
hey folks .. i updated to the 4.0 version ( virtual dj ) and I know get an error saying "Internal Database Corrupted." i "bought" the software this summer and it was doing fine till i updated to the new version.
- when i start up the program... it works, but the sound muffles anytime i fiddle with the equalizer or the volume control on both left and right channels. if i play around with the cross fader the muffled sound also creeps up. anyhow, theres obviously something wrong .. just wondering how i can fix the problem. thanks in advance.. mario
geposted Mon 09 Oct 06 @ 2:24 am
DJ-ALFPRO InfinityModeratorMember since 2005
First update to 4.1, if you didn't get the update, ask e-service for it.
About the sound, you should lower performance tab in settings and disable Overclock and Safemode options. For the new sound engine you need a very powerfull computer.
geposted Mon 09 Oct 06 @ 9:08 pm
