Forum: Old versions
Topic: VDJ 2 Update for Hercules DJ Console???
pia2000Home userMember since 2004
Hello,
what iss with the Update ( VDJ 2.0 ) for DJ Console??
geposted Fri 16 Jul 04 @ 9:00 pm
djtrickHome userMember since 2004
I don't think there will be one for Dj Console, because 2.00 is the hole new program, and it's not free....
geposted Sun 18 Jul 04 @ 3:23 pm
The Hercules DJ consoles users can download any add-ons ?
geposted Mon 19 Jul 04 @ 10:28 am
The Virtual DJ v1.09 is specially adapted for the dj console. Add-ons are only possible if you buy the full version of Virtual DJ. At this point there is no intention of the crew of Atomix Productions to make a 'special' version v2.0 for the dj console. If you want to use it, then you have to buy it.
The dj console is a package with 'such as is': small price, working perfectly with the adapted software.
geposted Mon 19 Jul 04 @ 12:22 pm
ok, are the DJ console and VDJ2 compatible ?
I mean, if i already have the DJ console and i download VDJ2, will it work ?
geposted Tue 20 Jul 04 @ 9:14 am
yes.... vdj 2.0 is FULLY compatible with the dj console...
and the dj console works even better in version 2.0, where u can even scratch with the jogwheels! ;) (and the scratch is pretty cool too...)
dj in norway
geposted Tue 20 Jul 04 @ 9:40 am
