I've raised the following ticket with the team:
"Settings for Hercules MK2 have been changed with 4.1. I cannot do the pre-listen when I switch from Deck A to Deck B or viceversa. If I'm at the mix position, even if crossfader is at deck B and deck's A volume is at 0, I can hear what is being played on deck A at a very low volume. I know I have the right settings as I have been using VDJ for a while now. How can this be fixed? Are you aware of this bug in 4.1?"
I thought I would post it here just in case someone has the exact same problem. I will post you any answer I might receive to keep you updated.
In the meantime, I've gone back to 4.0 and everything is working fine again.
I hope this is fixed soon. Not a big deal as it will definiteley will, as usual...
Regards
Regards
geposted Tue 10 Oct 06 @ 10:38 pm
Currently in v4.1, connect the DJC like on the picture here:
http://www.virtualdj.com/forums/57506/French_Forum/Pr__coute_dans_le_casque_avec_VDJ_pro_4_1___MK2__Solution_temporaire_.html
geposted Tue 10 Oct 06 @ 11:57 pm
Thanks! This fixed the problem for me!
geposted Wed 11 Oct 06 @ 12:16 am
Hi,
Can you guys post the solution in english, because I run into the same problem, and I also had to go back to 4.0.
Thanks,
Mario
Thanks,
Mario
geposted Wed 11 Oct 06 @ 6:54 am
Basically you need to configure your 4.1 version just as in the image in the french link. So go to Configuration and then in the Sound tab duplicate what you see in the picture in the link above. Try it and if it works, please let us know.
All the best
All the best
geposted Wed 11 Oct 06 @ 3:55 pm
